beave Posted October 5, 2011 Share Posted October 5, 2011 Not sure how to create them... I've searched for information, and have tried, but no luck... no I must ask the board! Quote Link to comment
michaelk Posted October 5, 2011 Share Posted October 5, 2011 (edited) It helps to know what version you have. Assuming a recent version with Architect: Tools > Reports > VA Create Schedule... > Window Schedule or Door Schedule and click for a place to insert. Any door or window with "On Schedule" selected in the OIP will appear on the schedule. Recalculate the schedule after changes. hth mk Edited October 5, 2011 by michaelk Quote Link to comment
beave Posted October 5, 2011 Author Share Posted October 5, 2011 Thanks Michaelk! Quote Link to comment
kquin Posted November 8, 2011 Share Posted November 8, 2011 kinda new to vw and read the above. i've added a window sched to my drawing as you said above but its showing multiple instances of the same window (used window sched summary and it shouldnt do that) anybody know why? Quote Link to comment
michaelk Posted November 8, 2011 Share Posted November 8, 2011 Hard to say with out a file or screen shot, but if you have design layer viewports in the drawing that may be the culprit. If you do, try opening the database header, right clicking on the database row header and choosing Edit Criteria. Then make sure that Including Components of: Design Layer Viewports is NOT checked. hth mk Quote Link to comment
kp2architects Posted November 15, 2011 Share Posted November 15, 2011 In the Door or Window schedule, is there a way to combine multiple instance of the same item? For example, say there are 10 occurrences of a window whose ID is 'W-01'. Then there are 6 occurrences of a window whose ID is 'W-02' and so on for 10 different window types. The window schedule tool creates a schedule that lists each window of each type. The schedule becomes huge, with 83 windows listed. I'd like to be able to condense the list so that only one occurrence of each window type (ID number) shows on the schedule. Is this possible? If so, how do I do it? Thanks; kp2architects VW Architect v.2010 27" iMac Snow leopard OS Quote Link to comment
John Meunier Posted November 16, 2011 Share Posted November 16, 2011 You can sum the columns by dragging the symbol just below the input field at the top of the worksheet Quote Link to comment
Pat Stanford Posted November 16, 2011 Share Posted November 16, 2011 To phrase what John said a little differently: If you open the worksheet for editing, you see three "buttons" at the top (bars going up, bars going down, SUM). These are not buttons, but tiles that can be dragged. Select a row in the worksheet and drag the tile to the column header that you want to effect. The SUM tile SUMMARIZES based on that column. It will consolidate all of the data that has the same value for that column. You can then put a formula of =Count in a different column to get the total number of items that are summarized. Once you summarize the data, other columns that have numerical data in them will also be summarized. If you have a window.width of 2 and a total of 3 windows that are summarized the column will show a total of 6. Drag another SUM tile to that column and it will undo the Summarize for that column. The other two tiles work similarly, but they sort the data in the column either up or down. You can combine SUM and Sort tiles in the same column. Quote Link to comment
John Meunier Posted November 16, 2011 Share Posted November 16, 2011 A much more in depth explanation than mine. Well explained Pat! Quote Link to comment
jaseweil Posted February 28, 2012 Share Posted February 28, 2012 I am working in VW2012 and have a door schedule that I want to order by door number. When I created the worksheet the doors were in a random number. I have tried to drag the order tile, but it seems to be greyed out and wont drag onto any cell or column. Any tips would be appreciated. Thanks. Jason Imac 24" 2.4GHz Intel Core 2 Duo Mac OSX 10.5.8 VW 2012 Designer w/ Renderworks Quote Link to comment
michaelk Posted February 28, 2012 Share Posted February 28, 2012 It's not a totally intuitive process: 1. Expose the database header (little triangle > Database Header) 2. Select the row header for the database. (In the default door schedule it's row 4 - it will have a little diamond next to the number) 3. Drag the sort icon (next to the little triangle [sort descending] [sort ascending] [sum]) to the column you want to sort by. (In the default door schedule it's column B) 4. Close the database header hth mk Quote Link to comment
Pat Stanford Posted February 28, 2012 Share Posted February 28, 2012 Not quite so complicated MK. Click on the row header for any database row (i.e. 4.2). It will select the entire row. You should now be able to drag the sort and sum tiles where you need them. No need to show/hide the database headers. Quote Link to comment
michaelk Posted February 28, 2012 Share Posted February 28, 2012 :blush: That's funny. I wonder how many extra clicks I've been doing over the last 10 years? Thanks again, Pat, for my perpetual eduction! MK Quote Link to comment
