Unnijv Posted October 4, 2011 Share Posted October 4, 2011 (edited) The tags appear with a marker on the first and the last plant when I use the poly-vertex placement mode . I would like to get rid of that. The same marker is there when I draw a landscape area.Any suggestions? Edited October 4, 2011 by Unnijv Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted October 4, 2011 Vectorworks, Inc Employee Share Posted October 4, 2011 It sounds like you have the Marker clicked on the Attributes palette. Click on the drawing area to make sure nothing is selected. Look at the Attributes palette. If one of the buttons at the bottom is clicked, this means that by default anything you draw will have an end marker. Hope that helps. Quote Link to comment
Unnijv Posted October 4, 2011 Author Share Posted October 4, 2011 When I highlight the plants the options in the Attribute pallette disappears. The pallette turns grey.So I cannot do anything. And when it comes to the landscape area I have tried to change the class, but it still has that marker (arrow). Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted October 6, 2011 Vectorworks, Inc Employee Share Posted October 6, 2011 Please send me the file - I will be happy to have a look at it for you. Quote Link to comment
Uli Posted October 7, 2011 Share Posted October 7, 2011 It seems to me that this discussion deals with a similar problem. I had also the strange behaviour with the marker and I also deselect everything an then set the marker in the attribute palette to on and off. http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=153127#Post153127 Quote Link to comment
