Hello Community! Our community board will be offline for maintenance as we perform an upgrade from June 8th at 8:30 am ET until June 9th. We appreciate your patience and understanding during this time.
Creating a Section Viewport on a Design Layer problem
Will
When I try to create a section viewport on a design layer, the viewport shows a plan? See attached screenshot. I can't work out how to make it show a section or elevation in this case. I'm sure I've followed the instructions in the help topic to the letter and it seems to work fine if I create a section on a sheet layer. Any ideas?
Thanks
Will
For interior elevations make sure your section line is inside the exterior walls parallel to what you want to show.
For exterior elevations make sure your section line is parallel to the exterior wall face.
You can control the height and depth of what you see beyond the section line
There are other ways also.
taoist
If you put a section viewport on a design layer, it obeys the view of that design layer.
Since the source and the section viewport are on the same layer, they are in the same view.
Section viewports put on sheet layers have individual (by viewport) control of their views.
Section viewports put on design layers show whatever view the design layer is set to.
You could move it to a different design layer and make sure unified view is turned off....
hth
mk
