VW 2012 open GL problem
dhruv
First of all the moment you switch to perspective view, the background changes to light green. Am i missing a setting?
Transparency is not working in Open GL.
In VW2011 tranparency id working in Open GL but it is not printing. I am using open gl with shadows and showing the lines.
The 'green' background colour provides a visual cue that you are now in a 3D view rather than Top/Plan View. The colours can be set to what you want in the Interactive Appearance Settings.
3D object transparency is only possible with Renderworks textures. To see the transparency in OpenGL renders you need to have Renderworks so you can apply a 'transparent' texture and then have this option on in the OpenGL Render Settings.
