Does Class Exist
michaelk
Miguels suggestion works if you know the whole name of the class. If you want to get classes whose name CONTAINS a substring I think you will have to loop through the class list.
I just tried ForEachObject and it appears to filter out classes.
It also appears that using '*' as a wildcard in a N='*None*' for example, does not return anything unless there is a character before the None while the final * allows for a zero length string.
I am filing a bug.
From the VW2011 VS Function Reference:
PROCEDURE NameClass
( className:STRING ) ;
Description:
Creates a new class in a Vectorworks document, which then become the active class.
If the specified class already exists, then it will become the active class of the document.
Note: Class names cannot exceed 20 characters.
If you use NameClass, it does not matter if it exists or not, it will simple become active.
Probably faster/easier to just get the active class, NameClass, reset active class than check for existance.
Pat
I'm actually trying to create the classes if they don't exist and set all of their by class attributes.
I think I understand most of it - except for textures.
There is a SetClUseTexture (boolean) but no GetClUseTexture. Am I missing something?
And how does one set which texture to use?
Thanks
MK
Michael -
Here is a Function that I use that I believe Gerard Jonker wrote a while ago that does exactly what you're needing, assuming you know the name of the Class:
{----- Function to Determine Existence of Given Class -----}
function existclass(Cstr : string) : boolean;
var
ci:longint;
stop:boolean;
begin
ci:=0;
stop:=false;
while stop=false do
begin
ci:=ci+1;
if Cstr = classlist(ci) then
begin
stop:= true;
existclass:=true;
end;
if ci = classnum then stop:=true;
end;
end;
If the Class doesn't exist, you can then store the active Class, create the new one and set it's attributes, and then "reactivate" the stored Class.
  • 1 year later...
