Rus 1 Posted September 21, 2011 Hello, I have recently got into Plug-in development with the SDK, with not much luck though. I am constantly getting these 2 errors when I build something (Even if it is a sample plug in from SDK folder): 1. Command /Developer/usr/bin/gcc-4.2 failed with exit code 1 2. mv: rename /SDK Vectorworks/SDKLib/ToolsMac/VectorWorks SDK Plug-in/Plug-in Library Stationery/build/Library./Contents/Resources/Library.rsrc to /SDK Vectorworks/SDKLib/ToolsMac/VectorWorks SDK Plug-in/Plug-in Library Stationery/build/Library./Contents/Resources/Library.qtr: No such file or directory Does anyone know what exactly is happening? Quote Share this post Link to post
Rus 1 Posted September 21, 2011 Also when I open the xcodeproj file with the sample plugin it can not find some references, unless I reinclude them like NNA_PluginBuild.xcconfig, NNA_StdBuild_Dev.xcconfig etc. And I unless the file MacTypes.r is included into the project it gives me error: 1. /SDK Vectorworks/SDKLib/ToolsMac/VectorWorks SDK Plug-in/Plug-in Tool Stationery/Tool.r:9:0 SysError 0 during open of "MacTypes.r". Quote Share this post Link to post
Rus 1 Posted September 22, 2011 Ok, so after hours of experimentation I have compiled an object .vwlibrary. Another set of stupid questions: 1.how do I access the .vwlibrary plug-in through Vectorworks? 2.Is there any way to decompile existing plug-ins and look at the source code. Thank you in advance. Quote Share this post Link to post
