Custom Selection Probelms
atelierva,
Make sure that you don't have your class options set to "Show Others" or "Show/Snap Others".
In order for custom selection to select a class, you has to be modifiable and visible. Make sure you to the Options menu and make sure the class options setting is the last choice, "Show/Snap/Modify Others".
Matthew GiampapaNNA Technical Support
Matthew - Not sure I follow your response. It reads as somewhat of a contradiction.
Katie- Edit Sheet Dialogue shows-Class Options: Show/Snap/Modify Others, Active Class: None.
No objects selected (Object Info Palette reads no object selected) when performing Custom Selection on Class is Window-Main in Sheet containing said class objects
