Kevin McAllister Posted August 29, 2011 Share Posted August 29, 2011 I would really like the Offset tool to work on 3D surfaces, including both curved (ie. Nurbs) and flat surfaces. Kevin Quote Link to comment
0 Kaare Baekgaard Posted August 29, 2011 Share Posted August 29, 2011 It works rather well for me. Quote Link to comment
0 Kevin McAllister Posted August 29, 2011 Author Share Posted August 29, 2011 (edited) Ok, I was able to get it to work this morning on some simpler surfaces but the intermediary step of Extracting surfaces or curves was needed. But you can step in from the edge of a curve, which is what I'm most interested in. Attached is an example. Note this curved surface is a pretty simple example (ie. parallel sides). KM Edited August 29, 2011 by Kevin McAllister Quote Link to comment
0 Kaare Baekgaard Posted August 30, 2011 Share Posted August 30, 2011 Hi Kevin I suppose I should read, "you can not step in". If you found a smart way to do that, I would like to know. The workaround for this is to use the shell tool on the curved surface of a duplicate, then subtract the shelled duplicate from the original, then extract the surface, you need, undo the subtraction and delete the shell. Quote Link to comment
0 ramooo Posted November 8, 2014 Share Posted November 8, 2014 I support the petition. It will be very useful for components of complex geometries like this one. Is there currently a tool to achieve something like that? Quote Link to comment
0 zoomer Posted November 9, 2014 Share Posted November 9, 2014 Ok, I was able to get it to work this morning on some simpler surfaces but the intermediary step of Extracting surfaces or curves was needed. But you can step in from the edge of a curve, which is what I'm most interested in. Attached is an example. Note this curved surface is a pretty simple example (ie. parallel sides). KM +1 Quote Link to comment
Kevin McAllister
Kevin
5 answers to this question
