Tom7 Posted August 19, 2011 Share Posted August 19, 2011 Hi, I'm new to Vectorworks and am having trouble fitting a sink into a cabinet. I think this might have to do with my inability to select the actual sink instead of the large box around it. Can anyone help me out, please? Thanks, Tom Quote Link to comment
taoist Posted August 19, 2011 Share Posted August 19, 2011 Make sure you are using a sink front type cabinet or it will never work. This is because a sink front type cabinet has no top. All other cabinets have a top. I do not mean countertop. Place one of each, view in Opengl, (3D) or other textured mode and you will see what I mean. taoist Quote Link to comment
Steven Kenzer Posted August 19, 2011 Share Posted August 19, 2011 Think in terms of what it would take to fabricate this. The first thing you would do is cut the opening out in the top. Determine the proper opening for the sink you've selected and create a rounded rectangle accordingly. Extrude that rectangle to a couple of inches more then your top thickness. Place it on and in your top, where the sink is going and perform the "Subtract Solids" command. That should give you the top with proper opening. Then drag the sink you want in from the Resource Browser and locate it in relationship to the top opening. Maybe someone else could suggest a quicker way. Quote Link to comment
Steven Kenzer Posted August 19, 2011 Share Posted August 19, 2011 Here's the result of that process I mentioned. Quote Link to comment
taoist Posted August 19, 2011 Share Posted August 19, 2011 skfurn, While what you state is correct, we should not have to do this. When we place a sink it should auto cut the hole. Other CAD Software does this, VW is behind on this point. taoist Quote Link to comment
Tom7 Posted August 20, 2011 Author Share Posted August 20, 2011 (edited) Make sure you are using a sink front type cabinet or it will never work. This is because a sink front type cabinet has no top. All other cabinets have a top. I do not mean countertop. Place one of each, view in Opengl, (3D) or other textured mode and you will see what I mean. taoist I am still having trouble with this. I changed the counter type to "sink front", but the issue now is that I cannot subtract the sink from the counter because I cannot seem to select both at the same time. I select the sink and the hold down shift to select the counter, but as soon as I press the shift key the counter becomes unselectable. It is on the same layer as the sink, not sure why it is doing this. I tried creating and extruding a rectangle to subtract from the counter but I have the same issue. Edited August 20, 2011 by Tom7 Quote Link to comment
taoist Posted August 20, 2011 Share Posted August 20, 2011 Tom, You must make sure you select the entire countertop depth. By default, the countertop has a reveal of 1/2". This means the bottom of the countertop (underside)has a rabbet at it's front bottom face. Plan view draw / place sink front cabinet Switch to a 3D view I use right side (#6) view, but left side (#4)view works just as well When you Modify > Ungroup the cabinet and countertop, you will what appears to be the full countertop overhanging the face of the cabinet. Below what appears to be the bottom of the countertop is a line, select that along with the obvious top. This line is the actual bottom of the top due to the reveal I mentioned above. Now go to Model > Add Solids Switch to Top /Plan view Select sink Create cutout shape for sink Model > Extrude shape to depth greater than countertop thickness Place extruded shape in cabinet to represent sink cutout Switch to a side view to get vertical offset correct Select extruded shape and Add Solid from earlier step Go to Model > Subtract Solids The Add Solids you created must be the object to keep, click OK Top /Plan view Place sink in hole (subtract solids) Switch to side view to align the sink vertically You can now save (if so desired) the cabinet and sink (save all) and save as a symbol for future use. Have you seen this video from Tech Support? http://kbase.vectorworks.net/questions/753/Placing+a+Sink+in+a+Base+Cabinet HTH taoist Quote Link to comment
taoist Posted August 20, 2011 Share Posted August 20, 2011 Here is screen shot of what I mean about countertop Quote Link to comment
Cadplan Architecture Posted October 7, 2011 Share Posted October 7, 2011 this seems to be a real chore for something that should be included as a simple function in Vectorworks. Why have they not done more when they have developed the software in other areas so much? I think we have to 'shout' a bit more to NNA as the upgrades are not cheap! Quote Link to comment
Joe-SA Posted November 18, 2011 Share Posted November 18, 2011 The independent Counter Top PIO includes controls for a sink hole. Just put in your dimensions and off set location. Go to your cabinet PIO and toggle off the included counter creation and then place the separate Counter Top PIO with hole on top of it. Why the original base cabinet doesn't include hole options is beyond me. Being able to input a symbol name into a PIO field and have it show up right where we want with over or under mount toggle would be nice as well. As is, base, counter, sink, and faucet all need to be separate PIO's or symbols stacked together. Joe Quote Link to comment
