James W. Johnson Posted August 17, 2011 Share Posted August 17, 2011 Hello, I would like to create a perspective front view of our stage from a top/plan view ground plan. Everything is drafted as 3D. I have been able to change the viewport settings to create a perspective drawing. However the "camera" or where we are viewing the drawing from is off to the side. Is there a way to change where the "camera" or viewing position is? Of course I know how to create a renderworks camera and create a perspective drawing that way. I want to be able to take all of the visibility settings in a top/plan drawing and create a perspective drawing from them. Via a copy/paste of the top/plan viewport then change the view settings. I guess another way I could do this would be to somehow copy the visibility settings from one viewport and apply them to another. Any ideas? Quote Link to comment
Pat Stanford Posted August 17, 2011 Share Posted August 17, 2011 Try this: Duplicate the viewport. Set the view to Front. Edit the Crop. Use the FlyOver, Walk Through, Translate View and/or Rotate View tools to reset the view to what you want. It sounds like the one you want is the Translate View to shift the objects back to the middle of the viewport. FlyOver is on the Basic too palette. The others are on the 3D tool Palette. Quote Link to comment
James W. Johnson Posted August 17, 2011 Author Share Posted August 17, 2011 Thanks! I forgot that you can compair visibilities when both viewports are selected. So I went through and did that for each for each of the ground plans to ensure they were the same. Thanks for the reply, I will try your work through when I get back to that project. Quote Link to comment
