Joel Riehl 0 Posted August 10, 2011 Sorry - I know this is probably pretty basic - but how do I get a door to insert into a wall (make an opening) instead of just sitting on top of it? This applies by extension to other objects such as windows, plumbing fixtures, etc., but the current problem is a door. They usually do it by default, but not this time, and I can't locate where to change the setting. Appreciate your help. Quote Share this post Link to post
taoist 17 Posted August 10, 2011 In plan view Select your door click on the wall where you want to insert Move the mouse to set the direction of opening and handing (right or left) and click to set. If this is the only door you want to place press the "X" key to escape or close out the Door function. hth taoist Quote Share this post Link to post
Damon Design 3 Posted August 10, 2011 Enable your wall insertion mode in the mode bar- the "button" just to the right of the scaling mode buttons. Quote Share this post Link to post
taoist 17 Posted August 10, 2011 Good point.D Door will not insert into the wall with out it. taoist Quote Share this post Link to post
