how to insert a door into a wall
Sorry - I know this is probably pretty basic - but how do I get a door to insert into a wall (make an opening) instead of just sitting on top of it? This applies by extension to other objects such as windows, plumbing fixtures, etc., but the current problem is a door. They usually do it by default, but not this time, and I can't locate where to change the setting. Appreciate your help.
In plan view
Select your door
click on the wall where you want to insert
Move the mouse to set the direction of opening and handing (right or left)
and click to set.
If this is the only door you want to place press the "X" key to escape or close out the Door function.
hth
taoist
