Ricker Posted July 22, 2011 Share Posted July 22, 2011 Something equivalent to the Mesh Smooth or Turbo Smooth modifier in 3DS Max. Quote Link to comment
Benson Shaw Posted July 22, 2011 Share Posted July 22, 2011 In Document Settings>Document Prefs>Display there is a Mesh Smoothing option with adjustable setting. Is this similar to the 3DS function? -B Quote Link to comment
Ricker Posted August 3, 2011 Author Share Posted August 3, 2011 I've never gotten that to work, nor have I found any documentation on it. Looking for something like the Poly Smoothing for 3D objects. Thanks, though! Quote Link to comment
propstuff Posted August 3, 2011 Share Posted August 3, 2011 Mesh smoothing usually works for me, although ocaisionally if you import Mesh objects into VW they will come as a group of bazillion 3D polys and not a mesh. In that case smoothing will not work. The polys can sometime be composed into a mesh, or if that doesn't work Export as 3DS and import back in will usually work. Very occasionally I've seen meshes not smooth with the command, but rarely. Quote Link to comment
Ricker Posted August 4, 2011 Author Share Posted August 4, 2011 Thanks! I'll try that! Quote Link to comment
