Mesh Smoothing
  • 2 weeks later...
Mesh smoothing usually works for me, although ocaisionally if you import Mesh objects into VW they will come as a group of bazillion 3D polys and not a mesh.
In that case smoothing will not work. The polys can sometime be composed into a mesh, or if that doesn't work Export as 3DS and import back in will usually work.
Very occasionally I've seen meshes not smooth with the command, but rarely.
