nakedeye Posted July 19, 2011 Share Posted July 19, 2011 Can anyone help me draw a 3d tunnel in vectorworks? what is the best way make an extruded rectangle and then cut thru it? Quote Link to comment
nakedeye Posted July 19, 2011 Author Share Posted July 19, 2011 thanks but what is the syntax? if i have a solid box with a cylinder running thru it how do i extract the cylinder? Quote Link to comment
michaelk Posted July 19, 2011 Share Posted July 19, 2011 Select both objects Model > Subtract solids > use the arrows in the next dialog box to select the piece you want to remain > OK hth mk Quote Link to comment
nakedeye Posted July 19, 2011 Author Share Posted July 19, 2011 Great thanks...that works Quote Link to comment
Benson Shaw Posted July 20, 2011 Share Posted July 20, 2011 Solid subtraction is fine. Another way is to extrude the shape. Draw a cross section of the tunnel as a 2d polylne and extrude that. Lofts also work, esp for a tunnel with varying cross section. Draw each cross section as a NURBS curve or a 2d poly then convert it to NURBS. Arrange them in top view like ribs on a boat hull. Then simple loft along the ribs. -B Quote Link to comment
