Pat Stanford 1,433 Posted July 16, 2011 Someone on the Vectorworks mail list asked for a way to replace 11,000 circles with loci at the centers of the circles. This script replaces every circle in a drawing with a locus point. If you only want to do some edit the criteria in the ForEachObject line and use Layer, Class, Lineweight, Color, etc. to limit the objects that will be acted on. Use at your own risk. Procedure Test; {Replaces every circle in a drawing with a 2D loci at} {the center of the circle. Use with care after backing up} {the original drawing. Use at your own risk. Here there} {be dragons. No warranty expressed or implied. ;-) } {July 15, 2011} {? 2011, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} Var Hand1, Hand2 :Handle; Int1, Int2 :Integer; Procedure DoAction(Hand3:Handle); Var X1, Y1 : Real; Begin Get2DPt(Hand3, 1, X1, Y1); Locus (X1,Y1); DelObject(Hand3); End; Begin ForEachObject(DoAction,((ST=CIRCLE))); End; Run(Test); Quote Share this post Link to post
Pat Stanford 1,433 Posted January 28, 2015 (edited) Someone finally posted a request for the inverse of this this, a script to replace a loci with a circle, so here it is. Procedure LociToCircle; {Replaces every Loci in a drawing with a Circle} {centered at the insertion point of the loci. Use with care after backing up} {the original drawing. Use at your own risk. Here there} {be dragons. No warranty expressed or implied. ;-) } {Adjust the Const Radius = 1' to a unit an size appropriate to the requirement} {All Circles created will use the default class, color, etc of the document.} {January 28, 2015} {July 15, 2011} {© 2011-2015, Coviana, Inc - Pat Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} Const Radius = 1'; Var Hand1, Hand2 :Handle; Int1, Int2 :Integer; Procedure DoAction(Hand3:Handle); Var X1, Y1 : Real; Begin Get2DPt(Hand3, 1, X1, Y1); ArcByCenter(X1,Y1, Radius,0,360); DelObject(Hand3); End; Begin ForEachObject(DoAction,((T=LOCUS))); End; Run(LociToCircle); Edited January 29, 2015 by Pat Stanford Quote Share this post Link to post
LyleBrowning 0 Posted August 7, 2020 Is there a script for 3dLoci to Circles. I have subbed 3d for 2d and gotten an error. Quote Share this post Link to post
MullinRJ 203 Posted August 7, 2020 Hi Lyle, There is now. This script gives you an option to draw the circles on the Ground Plane, or elevate them to the height of the 3D Locus by changing the value of constant "Circles3D". See comments in script. I also added a dialog to let you specify the circle's diameter before the script runs. Procedure Loci3DToCircle; { Replaces every Loci in a drawing with a Circle } { centered at the insertion point of the loci. Use with care after backing up } { the original drawing. Use at your own risk. Here there } { be dragons. No warranty expressed or implied. ;-) } { Adjust the Const Radius = 1' to a unit an size appropriate to the requirement } { All Circles created will use the default class, color, etc of the document. } { January 28, 2015} { July 15, 2011} { © 2011-2015, Coviana, Inc - Pat Stanford pat@coviana.com} { Licensed under the GNU Lesser General Public License} { 08 Aug 2020 - Raymond J Mullin } { This is a modification of Pat Stanford's script to convert 2D Loci to circles. } { This script will convert 3D Loci to Circles on the Ground Plane if constant Circles3D is FALSE, } { or it will elevate the circles to the Z height of the 3D Loci if constant Circles3D is TRUE. } { This script will also use a dialog for the user to set the Circle's Diameter. } Const Radius = 6"; Circles3D = TRUE; { Circles on Ground Plane if FALSE. Floating circles if TRUE. } Var Diam :Real; Procedure DoAction(H :Handle); Var X, Y, Z : Real; Begin GetLocus3D(H, X, Y, Z); ArcByCenter(X, Y, Diam/2, 0, 360); SetObjectVariableBoolean(LNewObj, 1160, FALSE); { circle on Gnd Plane } if Circles3D then Move3DObj(LNewObj, 0, 0, Z); { elevate circle } DelObject(H); { delete 3D Locus } End; { DoAction } BEGIN Diam := RealDialog('What Diameter?', Num2StrF(Radius*2)); if not DidCancel then ForEachObject(DoAction, T=LOCUS3D); END; Run(Loci3DToCircle); Have fun, Raymond 2 Quote Share this post Link to post
