Jim Smith Posted June 24, 2011 Share Posted June 24, 2011 I sometimes like to have a poch? or two on a hidden line isometric detail to give it more depth. I either do this in Annotation by drawing over a drawing if I'm in a hurry, or I have to add lights & render-much trial & error. I've tried Cartoon as an artistic style but this is not really acceptable in most cases. Does anyone have any other techniques? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted June 24, 2011 Vectorworks, Inc Employee Share Posted June 24, 2011 Hi Jim Have you tried using a sketched hidden line? Choose Hidden Line as the Background Render and then Edit the Settings. You can choose a Sketch mode for your Hidden Line render. Quote Link to comment
Jim Smith Posted June 24, 2011 Author Share Posted June 24, 2011 Thanks Tamsin, I have try 'em all. My goal from time to time is to produce IKEA style illustrations, Sketch-up does a not bad job of this, & it seems to me that OLD SKUL Renderworks did this until it was improved. (Where is the irony font when you need it?) Quote Link to comment
Kaare Baekgaard Posted June 25, 2011 Share Posted June 25, 2011 What is a Poch?? My dictionary doesn't tell. Quote Link to comment
mike m oz Posted June 25, 2011 Share Posted June 25, 2011 Poch? In a line and tone or pure tone drawing, we emphasize the shape of cut elements with a tonal value that contrasts with the spatial field of the floor plan . We refer to this darkening of walls, columns, and other solid matter as poch?. lt is typical to blacken the cut elements in small-scale plans in order to give them prominence. lf only a moderate degree of contrast with the drawing field is desired, use a middle gray value to illuminate the shape of the cut elements. This is especially important in large-scale plans when large areas of black can carry too much visual weight or create too stark a contrast. However, if plan elements such as flooring patterns and furniture give the field of the drawing a tonal value, a gray or black tone may be necessary to produce the desired degree of contrast between solid matter and spatial void. Poch? establishes a figure-ground relationship between solid and void - between container and contained. We tend to read the cut elements of a floor plan as figures and the bounded space as background. To focus on the shape of space as figure, we can reverse the normal pattern of dark marks drawn on a light surface and instead produce light marks on a dark surface. Page 138 of Francis Ching's book Design Drawing (1998 edition). Quote Link to comment
