Let us decide the z-order of wall components
Dieter @ DWorks
I want to be able to decide the z-order of wall components. This is because we use classes for the wall components, and not all those classes have black lines and are the same thickness. So now our walls show a black thick line and a red thinner line above each other where stone and insulation meet because the wall decided to put the insulation component on top of the stone component. If we could set the z-order of the components, this problem will be solved.
Now we have to manually override that line, but then you get problems at wall component joins so that some lines are gone.
2 answers to this question
