taoist
How do you apply multiple textures to cabinets?
I would like to be able to apply textures for countertops that is different that the cabinet texture.
Ex: Counter top - Granite texture
Cabinet Box - Cherry wood texture medium (light to dark)
Cabinet Doors - Cherry wood texture light or dark
Can this be done on the fly?
Can't figure out how to separate the components to apply different textures.
How do you use Styles for Cabinet, Doors, Kick, and Counter?
Are these editable on the fly or strictly pre-defined and I would need to create libraries (for lack of a better term) for different finishes.
Am I limited by the number of Style numbers?
I know I am asking a lot here, but I need to have a good understanding of how this works.
taoist
Vectorworks 2008, bummer. You have to assign a style to each part of the object, then use the Organization Dialog box to assign the texture to the class. In Vectorworks 2011, you can use your own names and classes.
Edited by Jonathan Pickup
Just to clarify (not meaning to step on your toes Jonathan). In 2008 there are a number of "Style" classes, named "Style 1", "Style 2", etc. First, as Jonathan says, use the Object Info Palette to select one of these classes for each part of the cabinet. Then go the Class Setup dialog and assign a texture to each of the classes you have chosen, making sure that "Use at Creation" is checked for textures.
The truly unfortunate thing is that because of the way these objects are "constructed" in VW's, there is no way to control the direction of the wood grain on separate pieces of the cabinet. The workaround is to Ungroup the cabinet and assign a texture to each piece. But that's a long way to go and you lose the parametric abilities of the cabinet.
Another possible solution for those doing a lot of detailed millwork is an add-on called "InteriorCad". Here is a link: http://www.resolve.ca/interiorcad
If you are creating a lot of cabinetry (millwork), then I recommend interiorcad XS. I have noticed a lot of clients buying and using this for interior design. It is very powerful.
Peter and Jonathan, Thanks.
Is what I want to do any easier in VW2011?
Yes, we do a lot of interiors (kitchens, baths, etc..)
I like VW2011 rotatable hatch/texture feature on planar surfaces.
This will be great for showing tile textures as we have clients sign off on tile patterns.
Need to utilize more of VW 3D ability for interior renderings.
taoist
As far as I know the cabinet pio has not changed much (if at all) from 2008 to 2011. However the dreaded "Style" classes are gone. Now you can name your own class(es) for any of the parts of a pio...
Peter, Thanks.
Seems like I need to upgrade to VW2011 and get InteriorCad.
taoist
Hi taoist,
If you're interested in interiorCAD, get in touch with Tom Pearce. Tom is an old friend to VW as well as a talented woodworker.
Here's Tom's email -
Tom@Coronal.net
Wes
Wes,
Thank You.
It has been awhile since I spoke with him.
I should upgrade to VW2011 1st then get Interiorcad version 2011
Will give him a shout.
taoist
