mediasets Posted March 25, 2005 Share Posted March 25, 2005 When I create a 3d object in plan view, how can I move it precisely along the 3D axis without dragging it in the front or side views? I'll select a 3D object and when I look in the object info palette, I see no information describing its position along the Z-axis. Also, in the duplicate array box, there is no option to duplicate along the Z-axis. Is it possible to duplicate along the Z-axis? Thanks cinema4d@fusemail.com Quote Link to comment
gdickson Posted March 28, 2005 Share Posted March 28, 2005 Use the Move 3D command from the Tool menu or Ctrl Alt M shortcut and specify the Z height requirement. Object Info palette will only allow you to edit the 3D objects size not position in the Z axis. To create duplicates in the Z axis you would need to view from Front position and then use Duplicate Array treating Y values as Z information. Hope that helps. Cheers gdickson Quote Link to comment
