florag Posted May 31, 2011 Share Posted May 31, 2011 I'm using vw 2009 and i need to create a cushion/pillow to fit on top of this curved corner seat (see image attachment) Any help would be much appreciated as I'm clueless! Thanks! Quote Link to comment
gScott Posted June 2, 2011 Share Posted June 2, 2011 1 make a 2d poly the shape of the cushion < i guess the shape of the seat plus or minus a little? > 2 extrude it to the cushion thickness 3 use the "fillet edge tool" to fillet the top and/or bottom edges of the extrusion. you can set the radius of the fillet as you use the tool in the [...] option 4 the extrusion then becomes a fillet and the radius can be adjusted in the OIP hope this is what you're looking for... Quote Link to comment
Horst M. Posted June 3, 2011 Share Posted June 3, 2011 (edited) If you want more a a Sofalike Cushion, you could try the Loft Tool - Extract the Curves of the Corner - Create a Nurbscurve for the Cushion Section - Use the Birail Loft, with Create Solid checked - Mirror the result to get the lower Portion of the cushion. regards Horst M. Edited June 3, 2011 by Horst M. Quote Link to comment
Bart Rammeloo Posted June 27, 2011 Share Posted June 27, 2011 A bit more advanced (and in Dutch, but since it's a movie it should be more or less self-explanatory): http://www.youtube.com/user/MrVectorworks?blend=3&ob=5#p/u/0/Ztb2mQRZvGw Quote Link to comment
cad@sggsa Posted June 28, 2011 Share Posted June 28, 2011 http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=128419&page=1 http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Number=125880 hope this helps Quote Link to comment
