Cheryl Corson Posted May 29, 2011 Share Posted May 29, 2011 Relative to the correct-looking plants in my test plant bed, my plant tags are teeny-tiny. How do I control the font size, and must I do it for each plant, or can it be done globally with the plant tag class? (I see how to control the angle, circle, etc.) Thanks! Quote Link to comment
Jonathan Pickup Posted May 30, 2011 Share Posted May 30, 2011 If you are using Vectorworks 2011, you can create a text style for the font and size you want to use, then drag and drop the text style onto the plants, from the Resource Browser Quote Link to comment
mike m oz Posted May 30, 2011 Share Posted May 30, 2011 The placement text size is controlled by what you have set as the default text size (Size sub-menu under the Text menu) when you place the plant. To change it afterwards select the Plant objects and change the text size in the Size sub-menu under the Text menu. Quote Link to comment
