Developer Wiki and Function Reference Links Read more... ×
Assembly
Returning VAR to the OIP
How does one return information back to the OIP?.
Precedent:
Rectangle tool returns
Perim:
Area:
I believe what you want is a read-only parameter. Use EnableParameter to disable editing of the parameter.
-Josh
An alternative is to add a static text widget to the parameter list in the plugin setup event by using:
FUNCTION vsoAppendWidget(widgetType:LONGINT; mappingID:LONGINT; text:STRING; data:LONGINT): BOOLEAN;
widget types:
kFieldLongInt = 1;
kFieldBoolean = 2;
kFieldReal = 3;
kFieldText = 4;
kFieldCalculation = 5;
kFieldHandle = 6;
kFieldCoordDisp = 7; {dimension}
kFieldPopUp = 8;
kFieldRadio = 9;
kFieldCoordLocX = 10;
kFieldCoordLocY = 11;
kWidgetButton = 12;
kWidgetStaticText = 13;
and the last one is what you would use to display information
I tried
vsoAppendWidget can't get this to load the file I can use
vsoInsertWidget.
This call is placed during the event of
kObjOnInitXProperties:
I can use:
vsoWidgetSetText(buttonID_3,Concat('FilePath:',p__Temp));
to feed information back to the field.
But the timing is odd.
The field only updates when I re:select the object. Ie deselect then select again.
It is not automatically updating?.
I noticed the same some weeks ago, it's a bug and Vlado informed us that it will get fixed in VW2012
Vlado on the VS mailinglist:
Yes, I see what you mean. Unfortunately, it should work but it isn't,
and this is a problem of VW. I'll fix it for VW2012.[/Quote]
Yes DWorks that is it.
I just realized I can use a static text type on the PIO and set that.
Easy
