B. Keesey Posted May 13, 2011 Share Posted May 13, 2011 I am using VW 2011 Designer and when I run anything that is moderately complex, the render drags and drags. my machine: MacBook Pro i7 2.3 GhZ Quad Core Processor 8GB RAM AMD Radeon HD 6750M Graphics Display my render: a stage a room (3) projection surfaces truss Curtains/Drapes a few textures (carpet, ceiling tiles etc.) Rendering w/ Final Quality Renderworks with a Hidden Line Sketch render in the foreground. I have eliminated all elements that contain too many polygons and vertices and tried to simplify all other elements. All classes the need not be renders have been switched off. I have menu meters installed and I watch all of processors go to 100% and it gets about 30% through the render and gets hung. I'm scratching my head as to why my fast machine would get hung on a render that doesn't have that many elements in them. I plan to put a lot more in there and it worries me that it cannot handle it at this stage. Does anyone have any ideas/tips as to why a render would be dragging on a fast machine? ...and yes - it's the only application running! BK Quote Link to comment
grant_PD Posted May 13, 2011 Share Posted May 13, 2011 Often it can be a corrupted object. Try custom renderworks with lower settings and work your way up. Final quality is overkill. Quote Link to comment
michaelk Posted May 13, 2011 Share Posted May 13, 2011 It's almost always a corrupt object. Multiple extrudes, sweeps, or mesh objects are usually the culprits. mk Quote Link to comment
