renderworks rendering everything white
oli w
This is a bizarre issue, I tried rendering a view that last night rendered absolutely fine, then I come to render today and everything comes out white and some things have no fill....if I do a render bitmap it shows all my textures up perfectly, then I try final quality, and its white. What on earth is going on? Im using 2011 on a mac pro, any help will be gratefully recieved
another point-the exact same thing renders fine in a earlier save from today, but then if i put the exact same object into the latest file, it comes out crazy. twice today I've gone back to an earlier file, had it work for a while, then at some point it'll stop working again. Im certain this isn't a memory issue, as the total file is around 120mb, and I have 12gb ram, and at no point is it getting even close to half filling that capacity
  • 5 years later...
