oli w
renderworks rendering everything white
This is a bizarre issue, I tried rendering a view that last night rendered absolutely fine, then I come to render today and everything comes out white and some things have no fill....if I do a render bitmap it shows all my textures up perfectly, then I try final quality, and its white. What on earth is going on? Im using 2011 on a mac pro, any help will be gratefully recieved
Hello oli w:
Can you post screenshots of what you're seeing? What render mode is the one that works, is that FQRW too?
Yeah it works in everything but renderworks...opengl is fine, bitmap etc fine...how do I attach images?Thanks
another point-the exact same thing renders fine in a earlier save from today, but then if i put the exact same object into the latest file, it comes out crazy. twice today I've gone back to an earlier file, had it work for a while, then at some point it'll stop working again. Im certain this isn't a memory issue, as the total file is around 120mb, and I have 12gb ram, and at no point is it getting even close to half filling that capacity
Hi, I updated to sp3 last night, and the problem appears to have stopped....
