Hidden line enhancement
For lines to dissappear, the touching objects needs to be structural objects. So you'll need to use a floor object instead of a solid for the roof. or run the following script when you select the solids so they are read as structural objects by the program:
PROCEDURE ToStructuralObject;
VAR
selected : HANDLE;
PROCEDURE SetAsStructural(obj : HANDLE);
BEGIN
SetObjectVariableBoolean(obj, 702, TRUE);
END;
BEGIN
ForEachObject(SetAsStructural, SEL=TRUE & INOBJECT);
END;
Run(ToStructuralObject);
This will turn the selected objects into structural ones so that you don't see a line between them in hidden line renderings.
This is also usefull for many other things like kitchen counters, drain pipes, things you want to split over more than one floor, ...
For VS beginners:
1- copy the script to your clip board ie. cmd c
2- In VWs go to Tools>Scripts>Vectorscript Plug-in Editor
3- in the editor choose New>Command and give it a name of choice eg. Convert to Structural and click OK.
4- highlight your (new) command in the editor then click Script
5- Paste the script (from your clip board) cmd v in the dialog window and click Save and then OK to exit the Editor
6- Now go to your workspace and add the command (which now should have appeared among all the standard commands) to your workspace.
7- select the objects to be converted and run the command.
8- render hidden line...now the offending lines should have disappeared.
9- thank Dieter Geerts - DWorks for his time and energy.
Edited by Vincent C
For VS beginners:
You can always add scripts to the resource browser. That's where I keep scripts like these in. There fast and easy.
VAR
selected : HANDLE;
BEGIN
END;
BEGIN
END;
And if you want to undo this, setting it ot non-structural, make another script, but instead of setting the var to TRUE, set it to FALSE.
