Peter Eichel 0 Posted May 12, 2011 When placing celestory windows I use the Elevation Reference "Head of Window". When placing a window below it that a client wants to be as close to the finished floor as code allows I use the Elevation Reference "Sill of Window". How do I edit the window schedule to show these dimensions in separate columns, one for the head height, the other for the sill height? Quote Share this post Link to post
michaelk 472 Posted May 12, 2011 You can use an if/then/else statement as the function/criteria in the database header. Check to see if the window is reporting the sill or head height and add or subtract the OA height. The attached has an example that simply shows which one is being reported and a field for the sill height and head height for each window. hth mk Quote Share this post Link to post
