HAUSrucker 0 Posted May 11, 2011 hi, i need to mirror buildings, but the space stamp is also mirrored! is there a opportunity to do this without a mirrored space stamp? thank you markus vw 2010 Quote Share this post Link to post
Mitchell Brooks 1 Posted May 11, 2011 Do you mean the text is mirrored? It doesn't do this in VW2011. Quote Share this post Link to post
michaelk 512 Posted May 11, 2011 It shouldn't do it in 2010 either... Make sure "Adjust Flipped Text" is checked in preferences. mk Quote Share this post Link to post
HAUSrucker 0 Posted May 11, 2011 i can read the text, but the order is flipped Quote Share this post Link to post
michaelk 512 Posted May 11, 2011 So instead of "Model Train Room" it the mirrored label is "Room Train Model" (and not "mooR niarT ledoM"? mk Quote Share this post Link to post
michaelk 512 Posted May 11, 2011 Hmmmm I just tried it w/ 2010 and this is what I'm seeing... The pref settings in picture 1 yield the results in picture 2 The pref settings in picture 3 yield the results in picture 4 The text within a field is correct. But which field is above which other field is inverted in a surprising way... mk Quote Share this post Link to post
HAUSrucker 0 Posted May 11, 2011 the room number is above the room name! Quote Share this post Link to post
mike m oz 373 Posted May 12, 2011 (edited) Most path objects don't mirror very well and you are better off not mirroring them. Space Objects come into that category. Your best option is to delete the mirrored copies and draw them again. Edited May 12, 2011 by mike m oz Quote Share this post Link to post
