dave sec Posted May 10, 2011 Share Posted May 10, 2011 hi! if i click on the 2d line tool in the basic tools palette, i click once to start drawing a line, and then click a second time when i want to stop drawing. is there some way i can arrange things so that a new line immediately starts where the old one ends? i realize the 2d polygon tool does this, but then it gets trick editing individual lines. and also when i use the polygon tool i end up with an enclosed shape. basically i'm trying to save myself having to double click all the time with the 2d line tool. it shouldn't be necessary. autocad and sketchup both allow you to draw lines without double clicking all the time. thanks! Quote Link to comment
Ray Libby Posted May 10, 2011 Share Posted May 10, 2011 You can use the 2D Polygon tool, then decompose into lines. Quote Link to comment
VincentCuclair Posted May 10, 2011 Share Posted May 10, 2011 There is a setting in preferences where you can choose drag and release style drafting, that could save you a couple of clicks...... Quote Link to comment
dave sec Posted May 10, 2011 Author Share Posted May 10, 2011 click-drag drawing is a step in the right direction. thank you! Quote Link to comment
Benson Shaw Posted May 11, 2011 Share Posted May 11, 2011 Would the 2d Polyline Tool help? Click once for each point, and/or use the tab key to get into cursor data entry. Edits are easy, esp if you know what point, length or direction you are aiming for. Completed polyline is not closed unless endpoint is coincident with the start. Apologies if you already know: If you are editing in cartesian setting in the OIP, switch to polar and see if you like that any better. Press/hold tilda key to temporarily disable all snaps. -B Quote Link to comment
