James Russell
Return In Message()
Hey all,
Just wondering if it's possible to put a Return in the Message() Function.
I want to return a concat I currently have:
Message(Concat('Increment Dimmer: ',DimVal,{/Return would go here/},'Increment Channel: ',ChanVal));
Anyone know if/what to put here?
Cheers,
James
It may not work but it would be:
Message(Concat('Increment Dimmer: ',DimVal,CHR(13),'Increment Channel: ',ChanVal));
but I'm not sure if a message window will properly deal with a return character on both platforms. I have some memory of it working on one platform but not the other.
Kevin
Are you sure? Try this one:
Message('this is line 1',chr(10),'This is line 2');
It works on Mac for me.
If you need cross platform you may need to switch to CHR(10) [linefeed] or even CHR(13),CHR(10)
Pat,
This is what I've got at the moment:
Procedure Test;
Begin
Message('This is line 1',chr(10),'This is line 2');
End;
Run (Test);
Results are attached as well as variations to chr(13) and chr(13),chr(10).
It appears that it's identifying those characters as spaces, just judging by chr(13),chr(10) resulting in a double space.
Let me know what you think.
Cheers,
James
I just copied and pasted your script above into a new blank VW document.
I get two lines of text in VW2011.
In VW2010 I get the same result you do.
Sorry, I think you are out of luck until you upgrade.
Any news on this? Im also trying to write multiple lines of text into the same message box. None of the above worked for me.
VW 2011 was the first version that accepted Carriage Return (CR) characters in the Message Window; and Windows and Mac have different codes to accomplish this. The Mac uses CHR(13) for a CR while Windows uses CHR(13), CHR(10).
So for Mac:
Message('Line 1', chr(13), 'Line 2');
and
Message('Line 1', chr(10), 'Line 2');
and
Message('Line 1', chr(13), chr(10), 'Line 2');
and for Windows:
all produce the same output.
______________________________________
x + VectorScript Message
Line 1
Line 2
HTH,
Raymond
I'm using Win 10. Here is some info about your question.
If you want to force a new line in a message box, you can include one of the following:
The Visual Basic for Applications constant for a carriage return and line feed, vbCrLf.
The character codes for a carriage return and line feed, Chr(13) & Chr(10).
