rsa Posted May 3, 2011 Share Posted May 3, 2011 In VWarch 2011 I thought I could edit the size of the window in the schedule and have it change the actual window. For some reason that has stopped working... Anyone else run into this? Thanks. Quote Link to comment
michaelk Posted May 3, 2011 Share Posted May 3, 2011 Works for me. Can you post a file with a non-working window? Quote Link to comment
VincentCuclair Posted May 3, 2011 Share Posted May 3, 2011 Does this work for Windoor windows too? Quote Link to comment
rsa Posted May 3, 2011 Author Share Posted May 3, 2011 Figured it out.... I had removed the overall width and height columns so to just use the RO's and was trying to modify the RO width/height. (trying to get the schedule size under control...) Apparently you can not modify the RO dimension only the overall dimension. I'll either just leave those columns in the schedule or wait till the end of editing and delete them... Quote Link to comment
Vectorworks, Inc Employee Judah Warshaw Posted May 4, 2011 Vectorworks, Inc Employee Share Posted May 4, 2011 Just to verify...the RO dimensions are calculated fields. Same with masonry module and net glazed area. This is why they appear in the data tab of the door and window settings dialogs and you can not edit the values there either. Worksheets don't really know this fact...they only see fields. The "read only" factor is controlled from within the door or window. Quote Link to comment
