TimOlson Posted May 2, 2011 Share Posted May 2, 2011 HI all, just updated my MBP and did a fresh install of VW 2011, downloaded the latest SP. 2 things are generating VectorScript errors: refreshing instruments after making changes in LW5, (which actually does affect the change) and when using number instrument tool for dimmer values (which does not). here's a sample of the error log, very similar if not identical in both instances. hardware: MBP 8,2 2.2ghz quad core i7, 8g ram. peace, Tim O Warning: _4871 _4903 - String index or count must be from 1 to 255. Warning: _4871 _4903 - String index or count must be from 1 to 255. Warning: _4871 _4903 - String index or count must be from 1 to 255. Warning: _4871 _4903 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _4871 1 - String index or count must be from 1 to 255. Warning: _1229 _1242 - String index or count must be from 1 to 255. Seconds to Execute: 0.03 Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 2, 2011 Vectorworks, Inc Employee Share Posted May 2, 2011 These are just Warnings and not errors. The only reason you are seeing them is that you have Stop on Vector Script warnings turned on in the Preferences. If you are having a problem it is not due to these warnings. Quote Link to comment
