quote 3d
What do you mean by 'quote'?
Do you mean but type onto it? If so you need to set the text onto a layer plane.
-Set the 'working plane' onto one of the cube faces using the working plane tool.
-In the drop down menu (at the top of the window) select working plane.
-Select the text and use the OIP and select working plane.
I think you mean dimension.
You can create a dimension in 3D by setting the working plane (using the working plane tool) onto the face of the object you want to dimension.
Then use the drop-down menu for layer/screen selection and select 'working plane'.
Now when you use the dimension tool the dimension will be set to a 3D plane and rotate with the object.
Have a look at this page and view the video called 'Improved 3D Environment' - it's the first one on the list
http://www.nemetschek.net/library/index.php
The 'Improved Text' video is also worth a look (6th one down on the left hand column)
Edited by GWS
