Lenb Posted April 27, 2011 Share Posted April 27, 2011 I'm having trouble using the Key Note feature. I have made a Keynote Legend on a "General" sheet and wish to use the callouts on various viewports of plans. When I go to insert a keynote I set the preferences indicating that it use the database legend from the general sheet, I click to insert and select the note I want from the list, update it and hit ok. The note appears as a new keynote number and at the bottom of the referenced legend(adding a redundant entry). What am I missing? I simply want to use the numbered keynotes referenced to a legend on a sheet in the drawing. I've searched here and looked through help which was of little help. LenB Quote Link to comment
Mitchell Brooks Posted April 29, 2011 Share Posted April 29, 2011 I am not a big user of Keynotes but here is what I think is happening. You created a list of notes on a sheet layer as text, numbers and text, right? Now you want to refer to them as keynotes, yes? The keynotes actually come from a database within VW, and you add to the keynotes either through editing the database or by using the call-out tool, and in the IOP, indicate that it is to be treated as a keynote and which set of the database you want it added to. If I am right above, just use the call-out tool as a number to correspond to the note you want to refer to but don't make it a keynote in the OIP. HTH. Quote Link to comment
