This seems like a really basic one, but I was recently reminded how bad the basic select tool is in Vectorworks.
The trouble is that overlapping marquee selections, when using SHIFT to build up a complex selection, causes objects to be deselected. Tell me why? Any sane application would simply make you use a different modifier key to deselect.
Correct me if there is something I've missed in my 8 years on VW...or if this has changed since version 2008...otherwise my wish is for the ALT key to be required to deselect.
[Currently the ALT key is also used as a selection modifier to enable selection by a sort of cutting marquee rather than an enveloping marquee....so I guess a global preference would be required].
Chris D
8 answers to this question
