Laura Stone Posted April 13, 2011 Share Posted April 13, 2011 We've encountered a problem in VW 2011 where if an object with data is in a viewport on a design layer any numbers in the data are doubled. This doesn't happen if the viewport is on a sheet layer. I can't think of a reason why I'd want the data to be doubled, but even if there are people out there who'd want that as a feature there really should be an option to include or not include the data in the object info palette. Quote Link to comment
Dieter @ DWorks Posted April 13, 2011 Share Posted April 13, 2011 What do you mean the data is doubled? Do you mean that VW will find the object 2 times in a worksheet? If yes, then this is normal and desired. Viewports on design layers where 'invented' to use them like symbols in the way you can show multiple times a certain thing you drawed. Think about a room you did the interior of and you have this room 100 times in your appartement building, then you could use a DLVP for it, and thus you need to have all the items in a worksheet. I at first also thought this was not good, but at second thought, this is really good. You only need another way to define your worksheets. Quote Link to comment
Laura Stone Posted April 13, 2011 Author Share Posted April 13, 2011 Yes I did mean on a worksheet. I can see from your scenario that it could be useful in some circumstances but still think I should have the option to not have those items counted. Quote Link to comment
Pat Stanford Posted April 13, 2011 Share Posted April 13, 2011 You should be able to adjust the criteria for the worksheet database to exclude either the layer or class that the DLVP is on to avoid the double count. To me, the easiest is to put the DLVP on a separate layer and then exclude that layer in the criteria. Quote Link to comment
