Pete (STZ)
Degrees Minutes Seconds
Call me silly - but what buttons do you need to press to enter an angle as degrees minutes and seconds eg 125?25'32" in the object info palette
Not sure about the OIP, but in the Set Sun Position dialog you can simply type (eg): 42D08M32S, etc... Try it and see if it works in the OIP. I'm curious.
Easier to type in 125d 25m 32s
Works in all dialog box situations where you can enter an angle.
If you want to display dms in the OIP you need to change the angle precision to dms in the Document Settings -> Units dialog. This is a global change for the document so anywhere there is an angle it will display as dms.
