Categories: apply modifications to existent objects
Hi,
I am using vectorworks2010 basic.
I need to modify an attribute to a category (line thickness) and apply that to all existent object associated to that category. But When I apply my modification, it is not applied to all the category objects.
Any suggestions, please?
thank you ,
Nicola
It means that those objects not getting the changes have a line thickness other than the class thickness. You need to select all the class objects and select "Class Thickness" in the attributes palette.
As a rule, I always have the class atributes selected in the palette when nothing is selected which ensures all new objects will have the class attributes. If I need to change them to another class afterwards, all the selected objects will get the new class attributes when changed to another class in the object info palette.
