don Posted March 30, 2011 Share Posted March 30, 2011 I am running Vectorworks Landmark 2011 SP2 on a dell using Windows 7 pro. I have had a rare error come up when I am working on text blocks where it will say cannot edit text must zoom in. I can do nothing with that text block no matter how close in I zoom. What is causing this? This is a problem I encountered back when I was using 12.5 on vista. thanks Don Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted March 30, 2011 Vectorworks, Inc Employee Share Posted March 30, 2011 Hi Don, Have you tried setting the font size of the text block to the desired size? I'm thinking that VW may think the text is much smaller than it is within the text block, but setting the size will hopefully reset it. If you have multiple sizes of text in it, this may not be ideal, otherwise it'd be worth a shot. Quote Link to comment
don Posted April 19, 2011 Author Share Posted April 19, 2011 Changing test size did eliminate the problem. thanks Quote Link to comment
