Inserting Nuts & bolts etc
GWS
It would be a great help if the working plane would stay as selected and not revert to the default ground plane when selecting & inserting nuts, bolts, cogs etc.
At the moment you have to select the working plane then select the PIO and then, using the arrows in the working plane window, re-select the working plane again....and it can be a bit of a pain.
I've also noticed that the working plane reverts to the layer plane from the screen plane when using the mirror tool.
In short I wish the user defined plane stay selected until told otherwise.
2 answers to this question
yes, this has been an age old Bugbear for me too, which seemed to have been for the most part solved in v2009, but i can't remember if it was an improvement of 2009 or a workaround i can no longer recall the solution to . . . . . . .
it just worked from the view selected!
