Sloping site: workflow opinions from architecty types?
How would you set up the file if you had a plan where the building floor levels and walls will step up about 3 steps in 2 or 3 places?
Everything on one layer with separate walls at each level?
One layer with the external walls edited to provide the step levels?
Multiple layers for each level with wall heights on each layer?
etc etc
TIA,
N.
Does the design have storeys ie are there floors above other floors, or is it one storey where the floor, walls and roof cascade down the slope?
If it's the former, I would stick with one layer per storey, if it's the latter, I would have just one layer for the floor.
Layers are about walls as well as floors. Too many layers and the walls get fragmented or you're fiddling about with 2D representations on some layers, real walls on others.
HTH.
Edited by D Wood
