SharonP Posted March 25, 2011 Share Posted March 25, 2011 I am trying to cut a 3d section of a model that is viewing just fine in every way I look at it, but when I put the section line through it, it obligingly shows me the black arrow and asks me to choose which way I want to look at the section, and will then only go one way! I have tried doing this in another document, and it works fine. What have I done wrong? Is there some setting I have wrong? I have tried closing the document and VW and opening again, but no joy. Help please? Quote Link to comment
mike m oz Posted March 25, 2011 Share Posted March 25, 2011 (edited) Once you have the Section Viewport created select it and then try using the Reverse Direction option on the OIP (Object Info Palette). I know that doesn't fix your creation problem but if it works it will at least get you the result you want. It might also be prudent to do a Save and then a Save As of the file with a new name so you have a safety copy of the file. Edited March 25, 2011 by mike m oz Quote Link to comment
SharonP Posted March 26, 2011 Author Share Posted March 26, 2011 I have tried what you suggested, but at no stage could I find a reverse direction option on the object info palette. Quote Link to comment
Mitch Brooks Posted March 26, 2011 Share Posted March 26, 2011 Go back to the section call-up itself, click on it and in the OI panel, you can click on the "Reverse Direction" button. Mitch Quote Link to comment
mike m oz Posted March 27, 2011 Share Posted March 27, 2011 Sharon which menu command are you using? - Create Section Viewport. - Cut 3D section. Quote Link to comment
SharonP Posted March 28, 2011 Author Share Posted March 28, 2011 (edited) I am using the cut a 3D section command. I have been trying again today, and it is still not giving me any choice. Very frustrating as it is choosing the opposite direction to where I want the section to look!! Edited March 28, 2011 by SharonP Quote Link to comment
SharonP Posted March 28, 2011 Author Share Posted March 28, 2011 I have just tried using the Create Section viewport, and then converting to lines, and it has worked just how I want it to. So my question is, what is the difference/advantage of one command over the other, and can anybody tell me where I went wrong when setting up my drawing that meant the Cut 3D Section command wouldn't work properly? Also - I assume that the converting copy of the viewport to lines is not going to upset anything else? Quote Link to comment
mike m oz Posted March 29, 2011 Share Posted March 29, 2011 Sharon, I've just tried with the Cut 3D Section command and I can select either side. Can you try using the command in a new drawing. The disadvantage of the Cut 3D Section command is that it is a snapshot of the file at a particular point in time and it works by duplicating the objects on the Design Layers and consolidating them into a new single Design Layer. This snapshot does not update as changes are made to the original objects. Therefore if you do want an updated version you will have to repeat the process. The advantage of a Section Viewport is that it does update as changes are made to the original objects. It can also be managed - ie. the visibility of the Design Layers and Classes visible in it can be varied. Quote Link to comment
SharonP Posted March 30, 2011 Author Share Posted March 30, 2011 I am able to use the command in another drawing, just not the one I need to! I must have something wrong somewhere that is causing this to happen, but I have no idea what it is. Quote Link to comment
mike m oz Posted March 30, 2011 Share Posted March 30, 2011 Perhaps you should submit your problematic file to your NZ distributor and ask them to have a look at it. Is there a reason why you are using Cut 3D Section instead of Section Viewport? The latter has significant advantages. Quote Link to comment
rcarch Posted March 30, 2011 Share Posted March 30, 2011 The 'Cut 3D Section' command does not even show up in the standard workspaces or menus anymore. I would follow with Mike M OZ and try the 'Create Section Viewport' command under the View menu. Quote Link to comment
