RichieHatch
Item attribute applying
Hi
I have a problem with a few VW2008 files that we are currently working on. We are using Macs running Leopard and Snow Leopard and the problem persists in some of the files. Basically when you select an object (line/polygon/rectangle) and try to change or apply a new color or class style it refuses to accept the changes and remains in its original state. The only way we have found to solve the problem is by copying individual layers one at a time into a new fresh document but this means setting up our sheets and viewports again which is time consuming and annoying...! The files themselves are quite large (10000sqm school over 3 floors) coming in at around 30mbs. I know my description of the problem is sketchy but I was wondering if anyone had experienced and similar issues. I can email/dropbox a file for someone to test if necessary.
Regards and thanks
Richie
Can you delete everything from the file except one or two objects that are causing the problem and post the file here?
Yip.... tried copy and paste in place in the same file and it still applies. If I paste in place into a fresh new file all is fine. Not really an option for this file as I have serious deadlines over the next few days and dont have the time to be making new files etc...
Thanks
Richie
Ok here is one of the files in question. I have deleted everything except for 2 items that I cant edit attributes at all.... Let me know if it happens in your version of vectorworks...???
Thanks
Richie
It works as expected in VW2009 (the oldest version I have on this machine). I can change attributes successfully, change classes of objects, and change the attributes of the classes.
I know a lot of people say that they are running 2008 on OS 10.6, but I think 2008 is only supported up to OS 10.5.
mk
Also works for me in 2011 -
Have you tried Unchecking the Use at Creation selection of the Class - probably worth a try.
Thanks for testing that mk...! We are running VW2008 in both 10.6 and 10.5 and it is happening in both. Maybe its time for us to upgrade. The boss will like me telling him that. hahaha
Thanks again
Richie
Thanks bcd.. tried that and it still will not work...!!! I made a little video of the problem but its too big to upload.. if ye want a look just PM me..!
Thanks again
Richie
That file is very odd, and I can duplicate the issue on VW2008 on 10.5 but then I've had similar problems before. Did you import a DWG into that file at any stage?
Hi Chris...
As far as I am aware we never imported a dwg into this file. This file (before deleting everything) is the GA Plans file for a large school in Ireland that we are designing. There are 3 floor plans on separate layers and also a roof plan. Then the usual viewports and sheet layers etc etc. Nothing too different to other files we have here in the office. Yes we have also had this issue before but on a smaller scale drawing. In fact I think another of the files on this project has had to be completely renewed (by copying and pasting into a new file). Very odd indeed.... and very annoying too..!
Thanks
Richie
You sure you didn't bring an OS Plan in? This is the only cause of this issue for us previously and is caused by forgetting to untick "match lineweights to colors" when you import the OS.
It's like a little trick question to give to your colleagues though..."bet you can't change the colour of that rectangle!"
