Joel Riehl Posted March 13, 2011 Share Posted March 13, 2011 (edited) I am not familiar how to use these. I created flooring patterns for a project - in several different "groups". When I went to the sheet layer, one of them was invisible. I went back to the design layer, and it was there. When I selected all the pieces (which were drawn in one sitting, in the same "environment") the "Plane" button on the object info dialog box shows blank. If I pick the toggle, I get 2 choices: layer plane or screen plane. If I select either of these, half my lines disappear. If I select any individual object in this group of objects, the toggle reads "3d". I am assuming my objects are up off the 'Z' plane, but not co-planar with each other. Can somebody give me the reader's digest what is going on here, and what do these settings do for me? (Besides messing me up and bewildering me at the moment) Edited March 13, 2011 by Joel Riehl Quote Link to comment
mike m oz Posted March 13, 2011 Share Posted March 13, 2011 You can't globally make a Group either Layer Plane or Screen Plane. What you need to do is enter the Group by double clicking on it, selecting all of the objects and then make them either Layer Plane or Screen Plane using the pop-up on the OIP. In Design Layers: - Screen Plane objects don't exist in 3D space and will always float on the screen as the 3D view is changed. - Layer Plane objects exist in 3D space and will maintain their spatial location as the 3D view is changed. In Sheet Layer Viewports: - Screen Plane objects will only show when the Project Screen Plane Objects option is checkmarked. These objects will then appear flat on the Layer Plane at relative Z = 0. - Layer Plane objects will only show when the Display Planar Objects option is checkmarked. In Design Layer Viewports: - Screen Plane objects will only show when the Project Screen Plane Objects option is checkmarked. These objects will then appear flat on the Layer Plane at relative Z = 0. - Layer Plane objects will only show when the Display Planar Objects option is checkmarked. See attached images and explore attached file. Quote Link to comment
George Cocea Posted March 13, 2011 Share Posted March 13, 2011 (edited) www.vectordepot.com/plug-ins/ offers the "plane mode" pio which will convert globally all objects (no selection required) to either layer plane or screen plane. Edited March 13, 2011 by George Cocea Quote Link to comment
Joel Riehl Posted March 13, 2011 Author Share Posted March 13, 2011 Thanks much guys. That clears up a lot for me. Quote Link to comment
