The problem: usiing a 2010 file upped to a 2011 file one of the classes had "markers" set in the edit class dialog box and since there is not a "None" toggle I could not get it to stop drawing arrows!!!!!!!!!!!!
The solution: he said that I had to go to markers and select "custom" and make it "zero's" for angle and etc. This is a very unsatifactory solution please don't create dead ends like this. The reason given was "because ACAD import files can get messed up..........that's a sorry reason to frustrate me and not even give the simple toggle to fix it......All I want is "none"
At a minimum: in the help file give a reason for it and a fix it like listed above.
jdux
I talked with a tech.
4 answers to this question
