Davide Posted February 21, 2002 Share Posted February 21, 2002 Where are the shaft break, update date field /date stamo tools? They used to be in drafting aids, but no longer.Also it seems that when I try to add a command( in this case the "Position symbol" ) to the workspace in the tool menu I don't see it then in the menu itself. Is this a bug? VW Architect 9.5 on WIn 2000Thanks Quote Link to comment
Guest Posted February 22, 2002 Share Posted February 22, 2002 They are in the Drafting Tools.mcd file Quote Link to comment
Guest Posted February 22, 2002 Share Posted February 22, 2002 As for the position symbol command, did you edit the current workspace and was the correct workspace selected before you went into the workspace editor? When you drag the position symbol command over to the appropriate menu on the right, it should be listed there. Then when you click on OK it should reset the current workspace. You will see the screen flicker and redraw itself. It should be updated. If the update didn't take place, try to close the program and reopen the program. The command should be listed there. Quote Link to comment
