botto
3D Modelling
Good morning,
I'm having a problem ...
Introduce the 3D loci. Now I would like to put the 3d design.
Anyone can give me a little help? Commands that use?
How do I properly roundabout to quotas?
Thank you,
Pedro Botto
(excuse the poor english)
Hy,
Implement the project in a 3D flat terrain is easy.
But how do you do when the terrain is tilted?
I liked that indicate what commands should I study or that manual should I buy.
Thank you,
Pedro Botto
Hi Pedro
You need to change the Z value of your Loci to match the levels taken on site (in the Object Info palette). You can then use them as source data for a site model. However, I would recommend that you look at the Stake Object tool which you will find in the Site Planning toolset. It is a hybrid tool which will create your 3D Loci as well as creating a 2D plan view of the locus, with the height labelled.
You can also use 3D Polygons representing the contours on the site, again setting their Z values in the Object Info palette.
I am running a course on Site Modelling next week, but I guess the UK is too far for you to travel from Portugal! Good luck with the project.
Thank you !!!!!!
I'm sorry for not being available to move the UK.
For next ... who knows
See try the tips, thanks!
Hi Tamsin I'm new to VW (have attended intro and some 3D work) I'm working on project and have received a survey in .dwg format I need to work up into a 3D model - have traced contours and think I need to transform into 3D polygons in order to run 'create site model' confused.com any help would be v gratefully received :)
Hi Jo
Thanks for sending the files over - I have had a look and one of the files contains the 3D Loci that you want. You just need to check ALL 3D when importing to ensure the Z values are retained and then you are good to go!
All the best
