Geoff Knight Posted February 10, 2011 Share Posted February 10, 2011 After the focus of a light is set (in this case, a Par64), is there an easy way to rotate the beam without manually changing the degrees? Thanks! Quote Link to comment
Horst M. Posted February 10, 2011 Share Posted February 10, 2011 (edited) Hi, The way to focus lights in VW that I find easy to use is to set Fouspoints. To change the direction of the Light you just move the Focupoint to the place you want. Edited February 10, 2011 by Horst M. Quote Link to comment
Geoff Knight Posted February 10, 2011 Author Share Posted February 10, 2011 Sorry, I mean much in the way that on a par you can physically reach in the back of the light and rotate the globe to get the bottles to align for a longer narrower beam or a shorter fatter beam, or any angle in between. Once I have the hang position and the focus down in VW, is there a way (for lack of a better term) to "spin the bottles?" Quote Link to comment
