Tara Posted February 19, 2002 Share Posted February 19, 2002 I am not the architect in this equation, just the printer, so I have no idea how to use this program. We received a VW file (we have VW 9.01) that has text and every time i try to print it to our HP1055, the text does not show up. It is also not printing the whole page (i.e. the page is 35x90 and I set the page to 36x96 but it will spit out some paper and then start printing at halfway through the page). HELP!!! I need to get this done in a timely manner and I can't find help in the help sections or anywhere on these boards. Thanks! Quote Link to comment
Matthew Giampapa Posted February 19, 2002 Share Posted February 19, 2002 Tara, Are you printing from a Mac or from a Windows computer? If you are using Windows, try using the PostScript drivers for this printer as it may have different results. Likewise, if you already are using the Postscript driver, try using the hpgl/2 driver to print. Have you selected "One Page" in the set print area command? This will set the bounding box on the page to accurately describe what will print (assuming the paper is selected correctly in the print/page setup command) If all else fails, try printing this to a different device and see what the results are. Also, if you want to email the file to tech@nemetschek.net, we may be able to reproduce the problem here and find a solution. Matthew GiampapaTechnical Support Quote Link to comment
Tara Posted February 20, 2002 Author Share Posted February 20, 2002 Thank you for the information, Matthew. I've tried 2 different devices (HP 1055 &HP2500) with different drivers (post script and the HP driver). I've also set the print area to the correct size and the 'one page' option. I was able to get it to print the whole page when I selected "Current View" but it was too small because there was other stuff to the side of the page. I have e-mailed the file to the address that you gave me. Hopefully they will encounter the same problem and be able to talk me through it. I also didn't mention in my last message that the trees aren't showing up either. I noticed that the tree layer was on invisible, but when I make it visible, random trees pop up where they don't belong. Thank you for your help and I look forward to hearing from a tech representative regarding my problem. Thanks, Tara Quote Link to comment
Guest Posted February 20, 2002 Share Posted February 20, 2002 Tara, If you are still using 9.0.1 I would strong urge you to upgrade to 9.5. We fixed many print problems with the 9.5 release. Quote Link to comment
Tara Posted February 20, 2002 Author Share Posted February 20, 2002 I will talk to my manager about that- but in the meantime, can I find out if anyone has looked at my file? Thanks, Tara Quote Link to comment
Guest Posted February 21, 2002 Share Posted February 21, 2002 Hello Tara, Check out our web site for the FREE upgrade from 9.0.1 to 9.5: http://www.nemetschek.net/downloads/index.html You can download and install it as long as you have a registered version of 9.0.1. HTH, Quote Link to comment
Matthew Giampapa Posted February 21, 2002 Share Posted February 21, 2002 Tara, There is nothing wrong with the file, it printed without a problem on both a HP 755 and a HP 2500 using VectorWorks 9.5.0 and the v4.40 drivers from HP on Windows XP. I would really suggest downloading the 9.5 updater from our website and try printing from that version. Matthew GiampapaTechnical Support Quote Link to comment
CEA Posted February 21, 2002 Share Posted February 21, 2002 Tara: I am also located in Washington DC, and I am looking for a reprographics company that can handle Vectorworks files. What company are you with? Quote Link to comment
Thom Posted February 23, 2002 Share Posted February 23, 2002 Tara I had a similar problem on my 450C. Turned out to be a plotter resources problem. I needed to add ram to the plotter. A work around was to go into the printer preferences under the 'Advanced' button and switch memory resources to "computer" from "plotter". Quote Link to comment
